Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Important Notices:
This version focuses on system performance optimisation and fixes for existing features.
Main features:
1. Performance Improvements
Enhanced speed and responsiveness of the interface for better user experience.
Removed storage of unnecessary data to save more system resources.
2. Bug Fixing
Critical fixes for gateway connection feature.
Resolved heating-related issues.
What's new:
Alarm
Unlocked creating alarm zones for all types of binary sensors.
Possibility of changing and setting custom icons for Satel outputs and zones.
Dashboard
Reduced time of loading device tiles.
Loading subsequent items with scrolling.
Devices
Reduced time of loading device rows.
Loading subsequent items with scrolling the list.
More available icons based on device hierarchy.
Possibility to disable saving of device energy to the database.
Elero*
Correct handling of the ongoing device pairing process.
Regionalization of available features based on gateway frequency.
Energy
Comparing the same time periods on the Savings tab.
Chart of savings since the date of installation.
Interval for storing virtual energy measurement reduced to five minutes.
More user-friendly installation cost removal.
Gateway Connection
Information that the gateway is ready to use as a slave.
Information on incompatibility due to a different version of the Z-Wave engine.
General
Possibility of choosing more than one main energy meter.
Nice*
Other
Four new language versions of the recovery interface (DA, HU, LT, RU).
Added missing translations for several language versions.
Performance
Removed storing the charts-related data into RAM.
Reduced redundant requests to api.
Bug fixes:
Dashboard
Unresponsive interface and long loading times for large systems.
Devices
Device after reconfiguration changes its name, ID, and room assignment (ZW3).
Possibility of starting a few reconfiguration processes for one device (ZW3).
Removing queued action of setting parameter if the device entered sleep mode (ZW3).
Overriding the temperature set in heating schedule is not possible for FGT-001 (ZW3).
No support for FIBARO Heat Controller error notifications (ZW3).
No support for com.fibaro.hvacSystem device type (ZW3).
Incorrect support for MCO MH10, MH-S31x, MH-S41x devices (ZW3).
Thermostat in Auto mode added as linked device does not operate the switch correctly.
Some endpoints belonging to multifunctional devices (e.g. thermostats) are missing.
Virtual power metering value does not change after its editing.
Configuration parameter value is not refreshed after resetting.
No units for sensors connected to FIBARO Smart Implant.
Energy
Sum of energy consumed by all devices is not calculated properly.
Gateway Connection
No possibility to restore backup with previous software version.
State of devices added to slave gateway does not update and gateway needs rebooting.
Incorrect mapping of devices connected to FIBARO Smart Implant added to slave gateway.
No possibility to configure virtual power metering for devices added to slave gateway.
Incorrect support of FIBARO RGBW Controller added to slave gateway.
No possibility to select category for devices added to slave gateway.
Notifications
Devices that are discharged or unavailable still trigger notifications.
Other
VoIP feature does not work.
Profiles
Action assigned to the Quick App button does not start after switching the profile.
Scenes
Creating new global variable does not allow to use it in scenes.
Known issues:
Z-Wave Engine 3.0
Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
Gateway connection is not available in the new Z-Wave engine version.
* - does not apply to HC3L (Home Center 3 Lite)
