We will need to be a bit more specific.
This issue occurs with new Zwave Engine (beta) or current one?
Which device type is affected?
Z-wave 3.0 have Slowly reaction. I set manytimes temperature in app or in chrome. if Refresh screen, temperature is set back. If set him on heat controler, hc3 have long delay, than read set temperature.
If i pre-set change temperature in heat panel, temperature is corectly (in night cold, per day heat).
I use fibaro heat.
Setting temperature to Fibaro Heat Controller takes few seconds (this is a FLiRS - frequently listening routing slave device) - gateway needs to wake it up before sending actual commands.
How much delay we are talking about?
    If I set the fibaro head to control the climate panel, then the temperature change does not work manually or through the scene. I simply do not change the temperature value on the head set by the climate panel in any way, if I delete the climate panel for the given head, then I will set the temperature value on the head manually and by the scene.
    I use Z-Wave Engine 3.0
    Please reconfigure the devices, issues with controlling FGT-001 when it is on Climate Panel were resolved.
    From changelog:
    Overriding the temperature set in heating schedule is not possible for FGT-001 (ZW3).
