Jacławiciel 6
I know that there's a dedicated plugin for Fibaro HC2 integration but it doesn't show the current AC state. Besides of that it works.
I would like to use a REST API functionality to integrate CoolMaster with Fibaro but I am unable to get any response from the CoolMaster within the Fibaro.
Here's the example URL that I'm using to send the GET requests.
http://192.168.188.10/v1.0/device/283B96002DB8/raw?command=ls
controlHeaders = {['content-type'] = 'application/json; charset=utf-8'}
I already tried a couple of commands, v2.0 API version, different ports that are described as the default in your docs. Nothing works. Connection refused is the only response that I get but I believe it's from Fibaro. Both devices are in the same network (Fibaro's plugin works so...).
Here's the docs that I depend on.
Scene code in the attachment.
