After update have motion senzor cca 20% chance dont react on move. Anybody same problem?
All my sensors seem to work fine, Fibaro and Neo CoolCam.
Have got a change to check if there is a problem with just showing the state in the UI or those acually do not report their state?
can i help you to install zniffer on you PC or PC of you QA's?
Simple debugging in lua will give us the answer if this is just UI problem or not - or just refreshing the page after motion event which is not visible.
@messiah.rs @petrovoz  - have you cleared the cache?
Believe it or not but I am using it quite often ;)
vitam.
Michael, it's really root cause here. I think (IMHO) is layer between HCServer and LUA layer bindlua.
something wrong here.
the same behavior was probably at winter with some beta.
all events pass to event LUA machine with some delays.
my games in the prev weekend led me to the conclusion what both engines (environments) LUA QA and SCENE got events with delays.
and last. Michael some times (but not stable) events passed to LUA ok.
dziekuje bardzo, O.
Edited by hater
That is strange really, we have tested this on many different setups.
More than 1300 5.081.18 betas installed and those issues (with delays) are reported only by you.
I suspect that something is running in the background and consuming most of HC resources which causes delays - without debugging it this will be very hard to find.
I won't count to this list @messiah.rs and @petrovoz as we didn't determine if this is related yet.
log dump will sent via PM. no issues with CPU
Same here, slow reactions I did not had before. Though its not always. Sometimes reaction is normal and sometimes its to slow.
    After few test. I will be have problem with sleep mode in accesory.
    Hc3 - z-wave 3.0
    Senzor NeoCoolcam pdz07z - batery or usb
    Light - domitech bulb
    reaction is inmediatly.
    Samtimes senzor or bulb dont react. Dont have slowly reaction.
    Light dont on, or light dont off.
    1-2x per day senzor ignore clear room and dont off light.
    Or Ignore me in room: light dont on. Or senzor turn off light if detect move ( im 5 minute in room and light off ).
    i thing senzors go to sleep mode and dont woke up in right moment.
    In previously version all work right.
    Edited by messiah.rs
    • 4 weeks later...
    Ok problem repaired.
    Problem deals bulb. If bulb off any component stop or have delay.
    Repair : - remove all part what can by offline and add back on system.
