[17.10.2021] [09:16:58] [TRACE] [ZWAVE]: Home Center in learning mode
[17.10.2021] [09:17:00] [TRACE] [ZWAVE]: Learning mode error. Try again.
[17.10.2021] [09:17:01] [TRACE] [ZWAVE]: Adding devices complete
[17.10.2021] [09:19:56] [TRACE] [ZWAVE]: ID 0: NOP sending succeeded. The device has not been removed. Please use Learning Mode to remove it.
[17.10.2021] [09:20:58] [TRACE] [ZWAVE]: Home Center in learning mode
[17.10.2021] [09:20:58] [TRACE] [ZWAVE]: Learning mode error. Try again.
[17.10.2021] [09:20:58] [TRACE] [ZWAVE]: Removing devices finished
  • 3 weeks later...
Did you solve it ? i have same issue after firmware upgrade
    sorry, no.
    it was test OLD FIBARO PLUG.
    I haven't any new ZWave devices anymore. only ZigBee.
    1 hour ago, hater said:
    sorry, no.
    I have created a Fibaro supportcase  - and i can see in my firewall log that they are working to fix it right now
    5.082.15 (beta)
    Fibaro wallplug same error device still in only to remove by Swagger
    //Sjakie
    In most cases this error is the result of secondary controller added to network which is not reachable at the moment.
    Limitations of Zwave protocol.
    Yes - that was my issue. Solved by Fibaro support
