diamant 0
Hello, i have a fibaro hc3 with a lot of z-wave modules. I try to make a scene working.
When i turn on my lights on 25,50,75 or 100% the light behind my beamer screen is also on, what i'm trying to do is:
If the beamer screen is down (flush shutter on) only the light behind the beamer screen must be turned off continue... Also when i press the button on my remote control for the lights 100%.... When the beamer screen is up (flush shutter off) then the light behind the beamer screen May react again on all those buttons.
I try everything in the hc3 but it still not working, the only way is to do it be a trigger and not continue.
If it is not possible i wanna try this with a relay behind the beamer screen flush shutter 220 volt wire cut on and off with a other zwave relay switch.....
Thanks!
Robin
8 answers to this question
