HCL3 LUA - syntax help/list of properties etc...
Hi All,
In HC2 (LUA scene) was nice syntax help/list of device properties.
Where is it in HCL3?
Regards
Konrad
you can find it only in QuickApp editor window, create empty QuickApp, go to edit, select the Device Tree helper, select device of interesst, click on property or action to get the code generated for you - then copy it into your scene ... that's the way to go for now.
/monthly_2021_10/image.png.5c634e93126ce0ab78d7c13f7272af61.png" />
    This is "list" of parameters of thermostat MH7H in HCL3:
    and this is in HC2:
    /monthly_2021_10/2066896068_HC2-91.0.png.494e95646508519d885a0252111e27b2.png" />
    I have to ask support...
    Edited by GanzConrad
    1) Local connection
    2) Swagger
    3): pictures 1, 2, 3
    4) thank You Support!
