Update to beta remotely
Is there any option to update gateways to the latest beta update, using lua? (Specially hc3). Installer account does not give that option, we can only update to latest none beta....
And yes, there is some risk involved updating remotely to a beta version ?
Edited by Comfortica
5 answers to this question
yes, i made once QA for that (or let say, because of the installer app missing beta thing), can't find it anymore the thread, so check attached.
In principle upload it (it will select server based on HC model), change IP and user/pwd
The best is to download first, then check the status with (with check ActonID), and when that's fine to click on update.
Auto works normally as well, but might be problematic with huge backups or no space (as there is no check).
Youmight of course minimize that all code, and simple fire "update auto beta", but remember that the UI will not change at all, till the HC start to backup/update/reboot
Edited by A.Socha
removed quickapp
Please remember that for us that action is wrong if something happen (it always can) we will be not able to help you, and someone from HC location will be needed. So if you do update be close. That same you not update TV, car or phone when you are far from this device
@tinman sorry I need to cut of your quickapp, you can sent in on PM but i don't want other users use it w/o thinking. Believe me or not before adding that protection we got on support a lot of users mad on us that he is far from home and he can't connect to his house
no problem, this is probably why the original thread is gone. For installers (because they take the responsibility for broken HC if something goes wrong) that QA might be ok, but yeah, for general users you right, too dangerous.
    Yes, there is a certain risk involved,  we agree on that :) if you find the quickapp and are willing to share it in private, we will use it wisely.
    you got PM
