Simon W 0
I have a gate motor that has a "Gate open indicator" that outputs 24V to drive an optional indicator bulb. By default it flashes while opening/closing, but it can alternately be set to solid on with the gate open or closed. I'll have it set to be active (i.e. 24V active) on gate open. I want to connect the gate open output to the Smart Implant as an input so I can make my ZWave network 'aware' of the gate status.
Firstly I assume that 24V is too high, so I will need to step down to 3.3V with a switching regulator.
Secondly how I would connect that as an input for the smart implant - is it just a connection across GND and IN1 at <10V required? I think it is as described in the Smart Implant manual as a "2-wire 0-10V sensor" in section 4.5? It mentions in the manual that this setup requires a pull-up resistor but doesn't show it on the diagram - what else is required? The manual also says in 4.5 for this setup "the 12V supply is required for these type of sensors" - not sure how that is different from the device's normal power requirement?
10 answers to this question
