Need to control 2000W boiler
I need to control my hot water boiler which is declared as 2000W wich should be around 9,1A on 220V networ. So can I use single switch 2? I see that double switch 2 is "total 10A" but single channel is less than 9A that I would need.
So please help me what device to use.
6 answers to this question
Best option is to use an external powerful switch which controlled by single switch 2.
Works for years for me (same application: water boiler)
Edited by cag014
    So Fibaro don't have its solution, but I have to use third party switch. I ask this as I allready have Sonoff zigbee switch but I would like to replace it with something produced in Europe and not Chinese. Also I don't have space to put two devices in a wall.
    For example a Fibaro Wall Plug can switch 2500 Watt up to temporarily 3000 Watt. But a separate external switch like cag014 suggested has more switching capability to handle peak powers.
    3 hours ago, Didytz said:
    I would like to replace it with something produced in Europe ... Also I don't have space to put two devices in a wall.
    you might try Heatit Z-Relay
    Or HELTUN High Load Switch (HE-HLS01), Z-Wave rele modul 16A can be an option.
    40A - 9600W
