HomeWizard Wi-Fi P1 Meter
Dear forum members,
I have a HomeWizard Wifi P1 Meter connect to my energy meter and I would like to connect it to my Fibaro HC2 in order to be able to read out the power and gas use.
Who can help me with a LUA file which contains the program which I can set as a VD or Scene in order to present the power and gas values.
Any help would be very much appreciated.
Hildo
@HKrook Maybe this can help you:
On 6/11/2021 at 7:57 PM, Zooitje said:
I have a HC2 so I want to make a scene.
I tested it in a VD and that works with the following code (in a VD button).
(port = 80).
local self_id = fibaro:getSelfId();
local ip = fibaro:get(self_id, 'IPAddress');
local port = fibaro:get(self_id, 'TCPPort');
http = Net.FHttp(ip, port);
response, status, err = http:GET("/api/v1/data");
result = json.decode(response);
fibaro:call(self_id, "setProperty", "ui.TellerLabel.value", result.active_power_w);
Edited by SmartHomeEddy
Hi @HKrook,
I just came across your question and would expect that given the time since then you have it all up and running?
Any experiences, tips&tricks and maybe Virtual Device and/or code snippets to share?
Might want to purchase a HomeWizard P1 meter and see some nice integrations, but based on the HC3 features /version.
No luck getting my p1 to run on a hc2. Anyone with a ready to import VD for the homewizard p1 and maybe the water meter as well?
