Have to manually select home central every time.
I guess it shouldn`t be like this, every time I open the app when on LAN, I have to manually select the home central then it works.
From external access it comes right up.
Is it like this for everyone? Why? Any tips?
I think it has to do with the fact that an APP on a phone wants to give you the choice on which home center you want to arrange things. So it seems logical to me that you first select which controller you want to access. So yes it seems correct to me. Some have multiple setups.
    I don`t think that answer is correct, as it works as "it should" when off the local network.
    yes, when i wrote it i already thought....uhmm thats not right :)
    On the other hand, i would think - on the local network, it should also give a selection wich controller to use.
    Unselect "use as default" in settings...
    Thank you, now works.
    So why is it like this? ?
    I think this is BUG. This "select" works in opposite way. :-)
    Could you please check on current Yubii version (1.13.1)
    Hi, I set it back to "Use as Standard: YES" ,and it still works ?
