net.HTTPClient() always waiting for close connection from client side
hi!
Attention. Subj!
pure LUA code works properly
any browsers also works properly
QA LUA always dead by timeout
[QUICKAPP2468]: http://192.168.1.71/xled/v1/fw/version
[QUICKAPP2468]: error: Operation canceled
NB: twinkly lights QA doesn't work!
simple reproduce application
simple QA for reproduce
Edited by hater
  • hater changed the title to net.HTTPClient() always waiting for close connection from client side
i had similar issue with Davis AirLink, httpClient was never working (while Davis WeatherLink with almost same firmare works with same code), haven't found any solution for the magic close middle of httpClient thread.
However, api proxy worked, and tcp socket worked. When i look on your code, tcp socket might be better solution, try:
Edited by tinman
  • Thanks 2
    thank you friend, you always cool ?
    On 10/31/2021 at 7:52 PM, hater said:
    hi!
    Attention. Subj!
    Solved my issue, thanks very much!!
