Working with tables and GlobalVars
I am building this for my own educational purpose and got stuck thinking I was almost there.
I build a table that holds my devices and their id’s. The table tutorial helped a great deal.
/uploads/monthly_2021_11/image.png.6d663f504fed1c1881de45b42d665435.png" />
can traverse through the table. I store the table via an encode into a GlobalVar. Which seem to succeed.
Next I do a Get on the GlobalVar which is successful (status 200), I get a table when I extract the response (response.value).
But when I traverse with the “in pairs” construct I receive an error. Apparently, the response is now a string.
function getDeviceTable()
  response, status = api.get("/globalVariables/DeviceTable/",
    name="DeviceTable"
  fibaro:debug(status);
  fibaro:debug(response);
  fibaro:debug(response.value);
  local table = response.value;
  --local jtable = json:decode(table);
  --fibaro:debug(jtable);
  for k,v in pairs(table) do
    print("first level key: " ..k..", first level value: ".. tostring(v))
    --for k2,v2 in pairs(v) do -- This works because we KNOW v is a table.
      --print(" second level key: " ..k2..", second level value: "..v2)
    --end;
  end;
If I json:decode response.value the outcome is the same.
So, how do I get a response from the GlobalVar that I can work with?
Thanks for your help.
5 answers to this question
You don't end the path with a slash or add the extra table value....
    name="DeviceTable"
You do
response, status = api.get("/globalVariables/DeviceTable")
or simpler
fibaro.getGlobalVariable("DeviceTable") and you get the value directly - and then you json.decode the value.
    Thanks! However, the code both give the same output and result. For whatever reason this picture did not make it into the post.
    /monthly_2021_11/image.png.97e3c228b23e330b99a3c9052df81a9a.png" />
    I just do not understand how to work with the output as I keep getting errors.
    Ron
    local jtable = json.decode(table)   --- json.decode, not json:decode
    for k,v in pairs(jtable) do   -- jtable, not table
    @jgabI am flabbergasted. Spend day and a half on this and it turned out I should use json.decode instead of json:decode. I tried so many variations ...
    So how does this work in terms of convention? I use fibaro:debug but must use json.decode; when to use a ":" and when a ".".
    But thanks a lot for your help .. small things do matter.
    : is used when calling function in an object oriented way, passing on the object as the first argument (self)
    On the HC2 fibaro used the : calling convention even though they really didn't leverage the objeeecet model. On the HC3 it's the dot notation again. fibaro being just a table with functions. You use : when  calling QuickApp functions  as QuickApp is a class that creates the runtime QuickApp object. Inside QuickApp function you refer to the  object with the variable 'self'
    You could also do
    but it's more elegant to do
