I'm a bit lost with the alarms. I've set two alarms, one based on doors and windows, the other on motions.
I have some Fibaro wall plugs that are made to trigger a flashing blue/red/white signal when an alarm occurs.
But I'm not sure if this can work through the alarm panel or if it's needed to set associations directly?
Because when I edit the scene for an alarm trigger, unfortunately there is no "alarm" option on the devices, only turn on or off or toggle, and energy reset.
Thanks for your advices.
