See Jay 0
I've replaced a couple of Fibaro dimmers with a relay made by Philio. It's wired in and added to the HCL OK but I have momentary switches and by default it's set up to work with a toggle switch so it basically means that the lights are only on while the momentary switch is pushed in..
There is a configuration for this, the manual says:
"ZWave configuration, configuration parameter 2, function 1=edge/2=pulse/3=edgetoggle, size 1 byte, value 1-3, default 1"
It is this config parameter that I need to change from 1 to 2 so that a momentary switch toggles the relay between on and off, but when I go into HCL config for the slave/master for the device, I see nothing:
/monthly_2021_11/image.png.db67dd03268f1a95ab5cedbc7e3ec230.png" />Can anyone advise how I can set this parameter? Thanks
Edited by See Jaytypo
