JSON data - can't find the right way of grabbing info from data
Hi
I need to get the lockStatus from this, but I can't find the right way..
data.armState.statusType works..
but
data.doorLockStatusList.lockedState doesn't.
There's a [ in doorLockStatusList that isn't there for armState - but I don't know how that changes the way I need to get the info.
data.doorLockStatusList.lockedState.lockedstate doesn't work.
if I add data.doorLockStatusList.0.lockedState lua crashes
if I add data.doorLockStatusList[0].lockedState i get "nil" as result
if I add data.doorLockStatusList[lockedState] I get "nil" as result..
What am I msising?
"accountPermissions": {
"accountPermissionsHash": "###########################"
"armState": {
"statusType": "DISARMED",
"date": "2021-06-29T15:01:39.000Z",
"name": "Fibaro Verisure",
"changedVia": "REMOTE_APP"
"smartPlugs": [],
"doorLockStatusList": [
"deviceLabel": "2CBK DK42",
"area": "Fordør",
"userString": "Tina Thomsen",
"method": "TAG",
"lockedState": "UNLOCKED",
"currentLockState": "UNLOCKED",
"pendingLockState": "NONE",
"eventTime": "2021-11-06T10:28:01.000Z",
"secureModeActive": false,
"motorJam": false,
"paired": true
It's an array so you need to pick out an element from the array - in this case the first [1] element.
Beware, the reason it returns an array is that there can be multiple items in the array.
I don't know hoe the lock responds but it could be a list of previous users unlocking... and if you are lucky the last is the first.
    @jgab.. that worked BUT...
    why... when the json looks like this in json2table?:
    it says '0' .. which I tried...
    Because many other languages index arrays from 0 - like javascript and probably the 'json2table' tool you used.
    Lua index all arrays starting from 1.
