HomeAssistant integration mentions different Thermostat modes
Hi there,
I have two Heatit z-wave thermostats included in my Fibaro HC2 setup.
They both show up in HA, but one is reporting the state “auto” and the other has two states “Heat” and “off”.
The one with “auto” won’t let it control the device. When I change the temperature in HA it just pops back to the original setting. Read outs for temperature and set temperature are working fine, but changing the temperature is not possible.
The other one is running fine.
When I compare the attributes in Home Assistant Developer mode I can see the differences:
And
In Home Assistant this looks like:
/monthly_2021_11/3e862fa5ce9c31d82c7fa1dc80f82886f96c9753.png.5c4c74975ec61c203b0facc4f2f9122e.png" />
When I compare the two devices in the Fibaro API I do however not spot a setting which might indicate this difference. I’m at a loss where HA reads this attribute and where I should change it.
Who has an idea why the two Heatit devices look to be setup with the same paramaters and still show up differently in Home Assistant?
Thanks for the help!
Which versions of the Heatit thermostats do you have? And what is their firmware number?
    Woonkamer Voor Thermostat:
    Producer: Heatit
    Version: 1.2
    "zwaveInfo": "3,7,11",
    "zwaveVersion": "1.2",
    "firmwareUpdate": "{\"info\":\"\",\"progress\":0,\"status\":\"UpToDate\",\"updateVersion\":\"1.2\"}",
    Firmware reports back as up-to-date, but I don't see a specific version other than the 1.2
    Achterkamer Thermostat:
    Producer: Heatit
    Version: 1.2
    No ideas, Anyone?
    • 10 months later...
    did you ever fix this? i have the same problem
    Yes I did actually.
    I did a factory reset on the thermostat and then added it again to the zwave network. After that it reacted normally.
