could someone guide me to a solution ..... after updating my HC3 to version 5.090.17 every time I type the IP of the HC3 to enter the configuration mode it only enters the first time, I do a page refresh on It's configurator hangs. ... I need to clear the Cache so that it opens a login screen again .... but a new update fails again ...
I made all access releases in Chrome
I cleared 100% of the cache
I disabled all firmware and antivirus and nothing has changed
Scenes and quality control working fine.
thanks
Are you sure that you don't have few tabs with HC3 interface opened at the same time in your browser?
    Hi, M.Grajczak@
    yes, sure only one tab ..... same procedure I did with an HC2 and it works perfectly .... but the HC3 does not....
    also used Firefox .... same behavior.
    what I found is that if you click refresh the page several times (8 to 10x) it returns to the login screen.
    the console screen also doesn't expand unless you click refresh several times.....
    I used another notebook .... same behavior .... very strange ....
