I am using the Fibaro HC2 local access to get some data from the API and parse that with a small application I have runniong on a raspberry pi. This runs fine, but after a few days the HC2 is not available anymore via local access. The access using Fibaro ID however keeps working. I can't connect to the web UI anymore as well using the local IP address.
When I access the UI using Fibaro ID I don't see any specific error messages either.
After a reboot of HC2 it works fine again, but after a few days we have the same problem again.
Any ideas?
