Aeotec Multisensor 7
Hi there, i have question about Aeotec Multisensor 7.
It was successfully added to HC3 lite, its working ok, however there are no parameters, how it works? fibaro will release update or can somehow add it manually or is there template to download and import to hc3 ?
thanks
Edited by john1312143
5 answers to this question
Hi @john1312143.
You can add parameters by manual.
You have to uncheck the box use template.
On the Aeotec site you can find the pdf with parameters.
As we're still without template, here's a script to add the full parameter set. With some prolonged coaching, managed to get this out of perplexity.ai.
This will add all params with their defaults.
Easier option, swagger PUT /api/devices/{deviceID} endpoint, paste in this payload:
Hi There and thank you.
I used swagger to enter and it worked!
What is the field to enter the comment or description into the "PUT" payload?
Also, when I checked the use template checkbox in the parameters tab the extra parameters disappeared.
I must be missing something?
Edited by JohnCrx
Doesn't appear to be anyway of adding the comment through the API, so the script maybe the preferable option to add the parameters.
I think checking the template checkbox means use the included template, which doesn't exist, so the parameters added manually vanish.
