HC3 fibaro.setGlobalVariable ERROR
Rosavision
Hi there
I’m struggling to convert some basic code from HC2 to HC3
The following code works on HC2
--calls json table and decodes
local decoded_light_settings = json.decode(fibaro.getGlobalVariable("g_light_set"))
print("after decode json file")
--STEP 2 gets the relevant json table settings from the decoded table
local ref_1 = (decoded_light_settings.al_7.c)
print(ref_1)
fibaro.setGlobalVariable("g_al_warm", ref_1)
But I get this message on HC3 debugger
[11.11.2021] [17:39:28] [DEBUG] [SCENE18]: at top
[11.11.2021] [17:39:28] [DEBUG] [SCENE18]: after decode json file
[11.11.2021] [17:39:28] [DEBUG] [SCENE18]: 1
[11.11.2021] [17:39:28] [ERROR] [SCENE18]: (load):11: Assertion failed: Expected string
The error line is for the last line of the code .... fibaro.setGlobalVariable("g_al_warm", ref_1)
I’ve changed the syntax to what I think is correct but can’t get it to work.
I've set up the global variable with an initial value 0
Any help much appreciated
5 answers to this question
Yes, the ref_1 needs to be a string, now it's seems to be a number.
I believe that the HC2 did an implicit tostring on values to setGlobal
Hi
On HC3
I would like to get the lux value it is a number from motion sensor and add to global variable int_Lux  but I got an errro message:" Assertion failed: Expected string"
local value = fibaro.getValue(32, "value") -- get lux value
fibaro.setGlobalVariable("int_Lux",value)
Can you help me?
11 hours ago, iTibor said:
Hi
On HC3
Can you help me?
Try that
fibaro.setGlobalVariable("int_Lux",tostring(fibaro.getValue(32, "value")))
