HC3 data file syntax
I’m using decoded JSON data tables to set global variables so that lighting scenes set different light ambience during the day / evening.
The following line works OK but its clumsy to change the references numbers in the decode string for each code line
Instead of this
decoded_light_settings.rgbw_4.r
I’d like to do this
Ref=4
decoded_light_settings.rgbw_(ref).r
but I can’t figure out the correct syntax
The complete code I’m using is….
local decoded_light_settings = json.decode(fibaro.getGlobalVariable("g_light_set"))
local ref=
{decoded_light_settings.al_4.c, decoded_light_settings.al_4.w, decoded_light_settings.rgbw_4.r, decoded_light_settings.rgbw_4.g, decoded_light_settings.rgbw_4.b, decoded_light_settings.rgbw_4.w, decoded_light_settings.rgb_4.r, decoded_light_settings.rgb_4.g, decoded_light_settings.rgb_4.b, decoded_light_settings.rgb_4.w, decoded_light_settings.sl_4.sl,}
local g=
{"g_al_cold", "g_al_warm", "g_rgbw_red", "g_rgbw_green", "g_rgbw_blue", "g_rgbw_white", "g_rgb_red", "g_rgb_green", "g_rgb_blue", "g_rgb_white","g_sl"}
if#g>0 then
for i = 1,#g do
--fibaro.call(g[i])
fibaro.setGlobalVariable(g[i], tostring(ref[i]))
Any help much appreciated
7 answers to this question
Instead of this
I’d like to do this
Ref=4
ref=4
decoded_light_settings[”rgbw_”..ref].r
1 hour ago, Rosavision said:
Hi @jgab I've run into another syntax challenge which after a few hours I need help !
Instead of this
num=4
decoded_light_settings[”rgbw_”..num].r
I'd like to do this
num=4
ref="r"
decoded_light_settings[”rgbw_”..num].[ref]
The following throws an error  [ERROR] [SCENE27]: (load):15: expected near '['
--local rgbw
--local bob
local rgbw={"re","gr","bl","wh"}
 local ref={"r","g","b","w"}
 num=6
if#rgbw>0 then
for i = 1,#rgbw do
fibaro.setSceneVariable(rgbw[i],decoded_light_settings["rgbw_"..num].[ref[i])
If I can figure this out I can get rid of a whole load of code and a bunch of global variables.
Can you see what I'm doing wrong? Thanks in advance for any help you can give me
No '.' between the indexes.
If
decoded_light_settings = { rgbw_1 = { r = '*1', g = '*2', b = '*3', w = '*4'} }
then
decoded_light_settings["rgbw_1"]["g"]
is equal to '*2'
edit:
has better solution... :-)
Edited by gbbsoft
    thanks @jgab & @gbbsoft. Worked perfectly, and it will help me a lot in future :)
    Instead of this
    num=4
    I'd like to do this
    num=4
    ref="r"
    --local rgbw
    --local bob
     num=6
    if#rgbw>0 then
    for i = 1,#rgbw do
    Hi again @jgab, I've beed reading your QuickApps coding guide for inspiration and have tried a few more things
    I get rid of the ERROR with this
    fibaro.setSceneVariable(rgbw[i],decoded_light_settings["rgbw_"..num.."."..ref[i]])
    But when I debug
    fibaro.debug("TestTag","rgbw red =",fibaro.getSceneVariable("re"))
    I get
    [DEBUG] [TESTTAG]: rgbw red =
    However when I use this
    fibaro.setSceneVariable(rgbw[i],decoded_light_settings["rgbw_"..num].r)
    The debug gives me this
    [DEBUG] [TESTTAG]: rgbw red = 180
    Thank you @jgab
    One "." has taken me all evening to fix, now it works like a charm :)
    Thanks you again sir
