matnowys 0
I've been looking for answers in this forum for a long time, but unfortunately couldn't find anything, so it's time to open a new thread.
I am using a solution in which the departure of users outside the home, triggers changing profile to AWAY. This profile turns off the lights, deactivates scenes with sensors (I have cats, so I don't want them to turn on the lights in my absence), change the temperature, etc. I do it through a series of scenes in which each of the family members activates the value of a variable dedicated to him. The cluster of variable values gives me a general presence in the house.
It looks like this in short:
1. If the user 1 enters the location of the HC3, the variable A changes to 1.
2. If the user 2 enters the location of the HC3, the variable B changes to 1.
3. If the variable A OR the variable B = 1, the variable of presence at home changes to 1 and switches the profile to HOME
4. If the variable A AND the variable B = 0, the variable of presence at home changes to 0 and switches the profile to AWAY.
In addition, I also use the Internet weather to determine whether the heating is to be turned on or not and at what temperature (which is included in the next two variables and added as conditions to the above).
This is troublesome as I have to create many, many scenes to achieve automatic profile switching.
QUESTION - can anyone tell me how to use geo localization triggers in a LUA on action side so that I can include it all in one scene?
I'm pretty new to LUA so forgive me in advance.
_____________________________________
Szukałem odpowiedzi na tym forum przez długi czas, ale niestety nic nie znalazłem, więc pora otworzyć nowy wątek.
Korzystam z rozwiązania w którym wyjazd użytkowników poza dom uruchamia przełączenie profilu na AWAY. Ten profil powoduje wyłączenie świateł, deaktywację scen z czujnikami (mam koty więc nie chcę aby włączały światła pod moją nieobecność), zmianę temperatury itd. Wykonuję to poprzez szereg scen w których każdy z domowników aktywuje wartość dedykowanej dla siebie zmiennej. Zlepek wartości zmiennych daje mi ogólną obecność w domu.
Wygląda to w skrócie tak:
1. Jeśli użytkownik 1 wjeżdża do lokalizacji centrali to zmienna A zmienia się na 1.
2. Jeśli użytkownik 2 wjeżdża do lokalizacji centrali to zmienna B zmienia się na 1.
3. Jeśli zmienna A LUB zmienna B = 1 to zmienna obecności w domu zmienia się na 1 i przełącza profil na HOME
4. Jeśli zmienna A ORAZ zmienna B = 0 to zmienna obecności w domu zmienia się na 0 i przełącza profil na AWAY.
Dodatkowo używam jeszcze internetowej pogody do tego aby ustalić czy ogrzewanie ma być włączone czy nie oraz na jaką temperaturę (co zawarte jest w dwóch kolejnych zmiennych i dodane jako warunki do powyższych).
Jest to kłopotliwe, ponieważ muszę stworzyć wiele, wiele scen aby osiągnąć automatyczne przełączanie profili.
PYTANIE - czy ktoś może mi powiedzieć jak użyć wyzwalaczy lokalizacji po stronie akcji w scenie LUA, abym mógł zawrzeć wszystko w jednej scenie?
Jestem dość świeży w LUA więc z góry wybaczcie moje pytania..
