I use Z-wave 3.0. On version 5.070 all works right. Friendly installer check my system. After update on last version system stop work mesh system. Many component have delay or bad working. Any help?
The installer couldn't solve it while he was at it?
it'S beta, so yeah, it might not work. I had actually some issues as well, so had to update mesh, but ...
... on zwave 3.0 there is currently no option availabe to update mesh, one have to:
- get z-wave stick and PC Controller sw
- include that stick (let it near your HC3, to avoid false positive routing), as device, to your HC3x
- click any mains powered device and click node infoand get version
- from IMA panel do redicovery and maybe netowrk health
- exclude zwave stick
- reboot HC3
- reboot HC3
summarized: hire an expert ???
(or downgrade z-wave engine)
oh well, this is actually bonus trick, till Fibaro implemented the mesh update into engine 3
Downgrade means everything from scratch
    Z-wave 2.0 dont read device right (newest device = binary senzor). On Z-wave 3.0 work so much more devices. Downgrade its not good way.
    Problem repaired: i remove all bulb and add back. Propably many component use bulb for resend signal. Samtimes 24hours without lags
