Danalock v3 I don't see any parameter
Hello
I tried to include a Danalok v3 but I don't see any parameters. What am I doing wrong? Via the app I updated the lock to the latest firmware and still
One more question are there two versions of the castle? Once with plus and one without?
I need help for the lock.
Thank you in advance.
My parameterlist is empthy but you can add them
//Sjakie
Try to ask Fibaro support.
You can add parameters manually  ->
It will be the same as you set the settings in the Dana App.
//Sjakie
It has not been integrated well, delete it and include it again with the lock less than 5 centimeters from the controller, the same thing happened to me and that was the solution.
Yep, it is hit and miss when including this lock. I have three and they now work great, but I had to (re)include them more than once.
Since I am on H3, since june, I include DanaLock just once.
//Sjakie
