Peppe 0
Hi All,
I'm no a professional programmer but I'm trying to make some basic code for my needs on HC2.
I wrote a code in order to get information from my SolarEdge system and based on that perform some actions like turn on the water heater, etc...
Unfortunately the SolarEdge system some times (from my test typically ones per day) responds with an error that generates a Lua fail aborting the scene.
This is the code I'm using for the HTTP request:
local http = net.HTTPClient()
http:request("https://monitoringapi.solaredge.com/site/"..SE_CLIENT_ID.."/powerDetails?meters=FeedIn&startTime="..SEendTime.."&endTime="..SEendTime.."&api_key="..SE_API.."",{
--options = {method = 'GET', timeout = 2000 },
options = {method = 'GET'},
success = process,
--success = function(response) fibaro:debug(response.data) end,
--error = error
error = function(err) fibaro:debug("Error:"..err) end
and this is one of the errors that I got during the day running the full code:
[DEBUG] 18:39:02: Error:Host not found (non-authoritative), try again later
Is there a way to avoid this issue and in case of an error in HTTP response just skip it and retry?
Thank you
4 answers to this question
