Api Request not working
Hello
I have a question about the Api request in software version 4.620
I didn't update my HC2 for a long time
Somehow the username and the Paosswirt are not correctly transmitted, so it is not possible to send an Api request here.
something has been changed here
how can I make a request here
not possible --> usr:[email protected]/api/devices
so what can i do ? any Ideas
I am not sure if this has anything to do with the version of the HC firmware, but the corrrect way to pass basic credentials with any HTTP request is to add an authorization header and leave the url unchanged. How to do this depends on the client doing the call. For example, given the username = "[email protected]" and the password = "secret1", you could execute this command from any Linux terminal:
Which results in the header "Authorization" with value "Basic bXkuZW1haWxAZXhhbXBsZS5jb206c2VjcmV0MQ==" (that is encoded username and password) being added to the request.
Or from Fibaro Lua script you would do:
