make small table with two values for each record
HC3
I would like to store a small table in global variable with a list of songname and the length in time of each song,  so can make a table which has the songs as a list, however i would like to also store alongside each song name the time it takes to play, can anyone please guide me on how to construct this table?  Thank you ever so much.
8 answers to this question
If each song name is unique and used as table key
Song titles are not unique and we only create an array of song records
    On 11/21/2021 at 4:46 PM, jgab said:
    I wanted to give each song a number as in S1, title,length, so would i just need to add this on each line?
    {number = 'S1',Name = SongName,length = 4*60}
    and then to retrieve the details of S1, print(song.number) or print (song.Name etc...?
    also in your return what is the ,"s" doing?
    s = seconds :)
    thank you @jgab
    is it possible to have more then just the title and value in a table, what i would like is, songnumber,title,length.
    how would write such a table and how would i get back the values?
    Here is example:
    On 12/22/2021 at 8:02 PM, petrkl12 said:
    Here is example:
    thank you,
    when i run this in scene if it is a basic table ie with just title and name i run this to get the value
    local jMT = json.decode(fibaro.getGlobalVariable("jMusicTable"))
    fibaro.debug("Scene47", "Play "..jMT.Song.S1)
    how do i reference the song name from your table example?
    1 hour ago, Jay Ess said:
    thank you,
    you can do it also this because it is array.
    songs2[1].title
    songs2[1].songTitle
    songs2[2].title
    songs2[2].songTitle
    songs2[3].title
    songs2[3].songNumber
    etc.
