Is there a guide to maintain the fibaro system?
What is the best way, If you want/need to replace a fibaro device?
- can you backup the configuration of a fibaro device?
- put that configuration in the new fibaro device?
- change the fiber device ID at one place, so you don't need to change all the scene's where that device is in it?
- what is the best structure to built this up to keep it reliable?
For this you can use a "HomeTable"plenty info here on the forum.
//Sjakie
    thanks for your replay. I wil look at it.
