Connection between Zehnder ComfoAir and Fibaro
Guest JeanOchmann
Hello all,
on the main page of fibaro they are mentioning that zehnder products are also compatible with Fibaro.
Now my question: How can I connect my ComfoAir Q350 which is also already connected to their Interface comfoconnect lan c.
Is there any possibility that I can also control or add it to my Fibaro System?
I am thankful for any support of you.
14 answers to this question
On 11/22/2021 at 9:24 AM, JeanOchmann said:
Hello all,
Hi Jean,
I would also like to do the same.  Did you make any progress on this?
Thanks Paul
Guest JeanOchmann
    Sorry no Progress so gar. Do you have any other Idea?
    Guest JeanOchmann
    Has someone any clue to integrate it with oauthw as there is now a possibilty
    You need to buy different module than comfoconnect lan c or You can built it yourself using FIBARO RGBW
    Zehnder is working on a Cloud API to connect to your ComfoAir at this moment it's in a beta stage.
    I tested their first cloud API only the login method needed a user interaction, so this login was not possible with Fibaro. Also with a workaround their where some issues.
    Based on our feedback Zehnder did an update on their cloud API now the login is "easier" at least at the application side. Only there are still some bugs to overcome.
    Let me know when there is interest in a quickapp for the Cloud API of zehnder then I keep you updated.
    Anything new? I need a solutions for this :-)
    @10i- do you know if the cloud API will still need a Lan C ?
    Yes the LAN C is needed
    Hello everyone, any news on this topic? Thanks!
    Hi, in my free time I'm making a QuickApp for controlling Comfortair Q (lan C) via Fibaro HC3 (not via Cloud API) with a limited set of commands and readable parameters. When the Beta version is available I'll let you know
    Edited by Kantapuna
    super. waiting
    update Kantapuna?
    Hi all, maybe someone already did integration?
    thx in advance
    Something new? I need a way to read the airflow form the Zehnder device. THX!!
