Virtual thermostat in QA - synchronise two heads by one temperature sensor
I need to manage (synchronise) two heating heads Popp/Danfoss with a temperature sensor (TS) Aeotec.
(Btw, I know this function has Fibaro heads and Fibaro temperature sensor, but I need to solve it with Popp/Aeotec.)
So I created a virtual sensor in Quickapps and connected it to a heating zone (see below the template of the VS).
The question is where I should place the code, periodically comparing the temperature from the TS and value from heating zone (heatingThermostatSetpoint property) and then managing (synchronize) the heads. I'm thinking about these possibilities:
- LUA scene triggered periodically (cron)
- LUA scene triggered by the change of temperature of TS  (is it possible?)
Is there any other, more elegant option?
Thank you for any clue!
Petr
QA Virtual Sensor template:
-- Thermostat heat should handle actions: setThermostatMode, setHeatingThermostatSetpoint
-- Proeprties that should be updated:
-- * supportedThermostatModes - array of modes supported by the thermostat eg. {"Off", "Heat"}
-- * thermostatMode - current mode of the thermostat
-- * heatingThermostatSetpoint - set point for heating
-- handle action for mode change
function QuickApp:setThermostatMode(mode)
    self:updateProperty("thermostatMode", mode)
-- handle action for setting set point for heating
function QuickApp:setHeatingThermostatSetpoint(value)
    self:updateProperty("heatingThermostatSetpoint", value)
-- To update controls you can use method self:updateView(<component ID>, <component property>, <desired value>). Eg:
-- self:updateView("slider", "value", "55")
-- self:updateView("button1", "text", "MUTE")
-- self:updateView("label", "text", "TURNED ON")
-- This is QuickApp inital method. It is called right after your QuickApp starts (after each save or on gateway startup).
-- Here you can set some default values, setup http connection or get QuickApp variables.
-- To learn more, please visit:
--    * https://manuals.fibaro.com/home-center-3/
--    * https://manuals.fibaro.com/home-center-3-quick-apps/
function QuickApp:onInit()
    self:debug("onInit")
    -- set supported modes for thermostat
    self:updateProperty("supportedThermostatModes", {"Off""Heat"})
    -- setup default values
    self:updateProperty("thermostatMode""Heat")
    self:updateProperty("heatingThermostatSetpoint"20)
Edited by PetrH
Hi PetrH,
I think, that not exists any other (more elegant) solution and the best solution in your case is storing LUA code in the scene launched periodicaly (eg. each 5 minutes). For this you should create scene based on LUA block and as trigger select Time Interval.
    22 hours ago, Tomasz Spaleniak said:
    Hi PetrH,
    Hi Tomasz, thank you for your opinion!
    Petr
