Dear users,
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
1. A new, user-friendly wizard for adding Elero devices
Device configuration within the pairing process.
Pairing multiple devices in one process.
Redesigned default icons.
2. Configuration of favourite positions in device settings Advanced tab
Easy, single-button step-by-step wizard.
Possibility to name positions and use them in scenes and profiles.
What's new:
Access
Mobile device status indication.
Dashboard
Distinction of actions sent on click and hold of the slat rotation button.
Support for holding the level change button on device sidebar.
Favourite positions buttons available on device sidebar.
Devices
Possibility of enabling inversion in device Advanced tab for blinds/shutters/gates etc.
Improved and unified support of device control types.
New default icons for switches, dimmers, shutters, gates, and garage doors.
Added icons for missing device states (favourite positions, brightening, dimming, etc.).
Devices of the com.fibaro.baseShutter type available in the Blinds linked device.
Improved detecting if device is awake and checking its wake-up interval.**
Added missing support for FIBARO Roller Shutter 2 FGRM-222.**
Reinterview process optimisation.**
Elero*
Configuration of device name, assignment, and its type as a part of pairing process.
Possibility of pairing multiple devices of different types in one process.
Testing the device detected during the pairing process to allow its identification.
Inversion feature enabled by default for devices detected as awnings.
Support for controlling the slats position.
Support for alarms and notifications.
Possibility of configuring favourite positions.
Possibility of changing the device role.
Possibility of forcing the device polling.
Support for Elero Unio-868, Combio-868 HE, and Combio-868 LI.
Energy
New Ecology tab for ecu-enthusiasts and everyone who produces energy.
Displaying self-sufficiency level, equivalent trees planted, and CO2 reduction.
Animated graphs of achievements and their impact on the environment.
Possibility of setting the return rate in Panel Settings.
Calculation of already returned installation cost including set return rate.
Redesigned interface for configuring additional rates in Tariffs.
Network
Access Point remains enabled after finishing FTI if no network is connected.
Nice*
Improved and unified support of Nice Mono devices.
Global abort for all types of binding procedures.
Quick Apps
Possibility of adding custom icon for all single-state devices (players, remotes, etc.).
Bug fixes:
Alarm
Alarm partitions (com.fibaro.alarmPartition) are not available as zones in alarm panel.
Dashboard
Holding the button on device sidebar does not work in mobile app.
Devices
Device properties and its interfaces are removed after the soft reconfiguration.
Soft reconfiguration of the device removes it from the linked device.
Maximum value reported by the sensor connected to analog input is limited to 4 digits.
In some cases, com.fibaro.baseShutter type device lose its configuration.
Incorrect setpoint temperature range for some thermostats.
Attempt to update firmware of some battery devices always fails.
Node provisioning list is not available.**
No power charts for power meters (com.fibaro.powerMeter).
Elero*
Incorrect default polling time interval.
Device is too early marked as dead but remains available.
Number of devices is not updated after removing the device.
In some cases, adding one device after another results in error.
In some cases, adding previously removed device is not possible.
Device polling is not stopped after performing action.
No Notifications tab.
Energy
No validation for entering negative values of measured energy.
Gateway Connection
Rebooting the master gateway always results in sending devices model to slaves.
Firmware update possibility disappears for devices added to slaves.
Nice*
In some cases, adding a new device is aborted before finishing the process.
No parameters after adding a device with parameters interface.
Device added on previous versions has its parameters disabled after performing update.
In some cases, clicking on remotes while binding is not always detected.
Redundant requests during device creating process.
No device calibration for BiDi Dimmer device.
Cannot bind new gate using its remote.
Incorrect default polling time value.
Notifications
System migration notification is restored and created after each reboot.
Other
Some HTTP requests do not require authentication.
Plugins
Recording feature in FIBARO Intercom plugin does not work.
Profiles
Some Elero devices are not available in profiles.
Scenes
No possibility to define multiple values in the date field.
Known issues:
Z-Wave engine 3.0
Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
Gateway connection is not available in the new Z-Wave engine version.
* - does not apply to HC3L (Home Center 3 Lite)
** - applies only to Z-Wave Engine 3.0
