k1s21 0
Hello I've been trying to get a fan running triggered by temperatures measured by DS18B20 probes.
The Fan is 12V and according to the spec needs max 0.08A, so I tried first a 12V 1A PSU to power both, but by the time i was wired up it had only 10.5 V at the fan connection. I tried another PSU, this time 12V 1.5A but only 10.8V at the fan connection - not sufficient to make the fan spin.
If the maximum current on the outputs is 150mA, why is the fan's 80mA / 0.96W not being received through the Smart Implant ?
The wiring from the PSU to the Smart Implant is 2cm. From the implant to the fan is 1 metre (using the cable supplied with the PSU ~12-14 AWG I thnk)
Edited by k1s2114 answers to this question
