Jay Ess 6
i have a global variable called sonosPlayer which stores the ip address of the sonos i want to play music to, the ip addresses are stored in the variable as a enum.
i have made a qa with a button which toggles through the different sonos ip addresses.
this is my function;
function QuickApp:ToggleMusicPlayer()
local gv = api.get("/globalVariables/sonosPlayer")
local MusicPlayer = fibaro.getGlobalVariable(self.gloVarNameMusicP)
counter = 0
for k,v in pairs(gv.enumValues) do counter = counter +1 end
if MusicPlayer == v then
if k < counter then
newK = k + 1
print(newK)
else
newK = 1
-- print (k,v)
if k == newK then
print(v)
fibaro.setGlobalVariable(self.gloVarNameMusicP,v)
self:MusicPlayer()
while it works i am cycling 3 times through the table and i wanted to know if there was a more effcient way to change the ip address without having to cycle so many times through the table.
6 answers to this question
