Output Satel integra 64+ still not switchable
In HC2 is was possible to switch an output on the Satel integra 64+. In HC3 this is stil not possible.
Is it possible to correct this in the new update.
I am waiting for a year now to get this corrected.
Thanks ,
Leon
We have some things related Satel integration on our roadmap for next releases.
I will try to speed things up, at least this one thing.
Michał
Outputs set to type [24 MONO Switch] or [25 Bi Switch] can be switched from HC2 and HC3 without problems. I have used it with HC3 for many months.
For example to trigger gate opening or to trigger lights at LUNA PIR Sensors. I also use it to transfer and map Fibaro sensors to Satel inputs (when Input is defined as "by output")
So where is the problem?
Other types of outputs cannot be switched from HC3, and it was also not possible from HC2, and it is related to Satel API and Satel limitations.
But I havent tried with Integra64+, only Integra32, 64 and 128. But they all works in the same way.
Edited by Albert
    Hello , For shure is was possible to switch satel outputs from hc2. I did it all the time and worked great. There was no need to use zones to switch.
    I need the outputs while i am running out of zones.
    Hello Albert,
    I don't understand exactly what you mean. I want to switch from fibaro an output directly on the satel. This worked great in HC2 and now when i push the button on fibaro nothing happens in Satel. When i switch the output in Satel i see in Fibaro the output is switched. I use the 24 and 25 switches in Satel . What is different between HC2 and HC3 then ? Or what am i doing wrong in setup. All other stuff works great.
