Gatriel 0
Hello all,
I am new to home automation. I am in the process of converting all switches on my ground floor (eventually the entire house but €€€ you know how it goes) to Walli-based products.
Most importantly right now are the Roller Shutter Switches, which aren't a problem ... but the question I have is can I setup a scene with Smartthings so that one Walli Switch controls the lightbulb (the "Master" switch if you will) while the other Walli Switch (the "Slave" switch) simply sends information to the master switch.
What I would ideally like to do is have the ring on both switches be red when the lightbulb is off and blue when the lightbulb is on. I want each switch to be able to turn the lightbulb on and off and simultaneously change the color of the other ring.
I have the Aeotec Smartthings Hub and would ideally like for this to work locally. I am unsure how the circuit is wired but assume each switch will have L/N 220/240 and one switch will control the light while the other switch simply communicates with the hub and thus the other switch as well. I am electrically handy so doing my own work isn't a problem. I am located in Germany if thats helpful information.
I assume this is possible, does anyone have any tips for me?
Thanks for everyone's help in advance.
4 answers to this question
