Hi. After the update, this lua scene stopped working for me:
  conditions = { {
      isTrigger = true,
      operator = "matchInterval",
      property = "cron",
      type = "date",
      value = {
        date = { "00", "00", "1", "3", "*", "2020" },
        interval = 300
  operator = "any"
local fromID = {58,63,68,73,78,83,88,93,98,144,236,241,260,275,333,338,343,425,472} -- Teplomery (Namerané teploty)
local toID = {57,62,67,72,77,82,87,92,97,143,235,240,259,264,332,337,342,424,471} -- Termostaty (Nastavené teploty / Setpoint)
local boiler = 226 -- Relé na ovládanie kotla
local flaq_1 = 0
for i=1,#toID do
    local name1 = fibaro.getName(fromID[i])
    local room1 = fibaro.getRoomNameByDeviceID(fromID[i])
    local name2 = fibaro.getName(toID[i])
    local room2 = fibaro.getRoomNameByDeviceID(toID[i])
    if ( fibaro.getValue(toID[i], "heatingThermostatSetpinot") ~= fibaro.getValue(fromID[i],"value") ) then
        fibaro.debug("", name1.. " / v miestnosti / " ..room1.. "  - Namerana Teplota: " ..fibaro.getValue(fromID[i], "value") )
        fibaro.debug("", name2.. " / v miestnosti / " ..room2.. "  - Nastavena Teplota: " ..fibaro.getValue(toID[i], "heatingThermostatSetpoint") )
                if ( fibaro.getValue(fromID[i],"value") < fibaro.getValue(toID[i], "heatingThermostatSetpoint") ) then
                        flaq_1 = 1
    else
        flaq_1 = 0
        fibaro.call(boiler, "turnOff")
        fibaro.debug("","vypinam kotol")
if (flaq_1 == 1) then
    fibaro.call(boiler, "turnOn")
    fibaro.debug("","zapinam kotol")
else
Where can there be a mistake?
This generates a message:
[29.11.2021] [18:16:51] [ERROR] [SCENE159]: /opt/fibaro/lua_engine/lua/engine/fibaro_sdk.lua:248: Assertion failed: Expected number
well thank you
You get that error if one of the deviceIDs don't exist.
Probably from fibaro.getRoomNameByDeviceID
Interestingly fibaro.getRoomNameByDeviceID returns nil for a non-existent device in QAs... which I think is a better behaviour.
Still don't understand why they keep different implementations of Lua fibaro api for scenes and QAs...
with different behaviors. (for example http)
it's look like Scene Team: ok! we are build own theme park with blackjack and ... (c)
You also seems to have misspelled heatingThermostatSetpinot
