The damn thing keeps disconecting ;/
ppeterr
I've been putting a multi sensor into use for weeks now. Can't seem to get that thing stable. As simple as it should be, it doesn't work.
One time it stays connected for a week, the next time the connection is gone a day later. Just a little while and I'll swing that nice ball over the hedge :P But maybe I'm doing something wrong, and do you have a good tip? I have set the wake-up time to 4000s, only set parameters 40 and 42 different. The rest is standard.
  • 2 minutes ago, akatar said:
    @ppeterr
    http://192.168.1.36/api/service/logsDump
    Thanks that works, got some dump file now. This is after the zwave service restart.
    I'll get one next time also when it is disconnected.
    thanks guys.
  • Thats funny, 4 days later - again the same problem.
    Made the logs, before i did the trick to reconnect. So, now i have logs before, and after.
    4 hours ago, ppeterr said:
    There is a pattern :)   4 days later. Again disconnect.
    Stable is ok.
    [trollface]
  • 27 minutes ago, akatar said:
    Did you sent the logs to fibaro support?
    This is not urgent :)
    Or at least, not for now. And i think Mr Roszak is on it also...
    So, if they need the logs, i will provide.
  • Oehhhh, what should i do......
    I updated to 5.092.19. Amd that went smooth.
    But now there is another....
    Oehh....this might be good :)
    Edited by ppeterr
  • Yesterday i did the 5.092.19 update. So far so good.
    Today, the connection with the sensor was lost, and the zwave -> smart start -> firmware upgrade tabs, crashed.
    Or, i think it crashed the whole zwave 3 service/protocol. After a reboot it all worked again.
    Then,  i performed the device update for the sensor, from 3.3 to 3.4
    This went oke..or at least, the version number stays on 3.3 after a succesfull update.
    @m.roszak
    I'm not sure now if the update went through. The option to update is gone. And the version is still 3.3
    @m.roszak
    try soft reconfigure or reconfigure and check the version again
    There is a notification in panel that device need to be reconfigured after successful update :)
  • On 12/24/2021 at 6:25 AM, ppeterr said:
    Thanks guys, that worked :)
    Well.......one day later..disconnected
    - zwave protocol error
    - 502 gateway error
    And it's reconnected.
    I must be doiing something wrong :) I dont see any other user having this problem
    having  the zwave engine crash on their system. Or am i wrong ?
  • I have submitted a case to the support department. With some logs.
    Edited by ppeterr
  • @m.roszak
    Something seems to have changed, for now it looks good.
    Not sure why, not sure how. But the damn thing keeps connected :)
    We have changes some things in backend for ZW3.0 in 5.100 - maybe that is why.
    As we did not reproduce this one it is a mystery :)
    hijacking topic a bit, but indeed that helped in my case with 3rd part sensor (700 series based) disconnecting all the time, on HC3 with zw3. Since 5.100 no issues since 7 days.
