Problem to understand the Fibaro Smart Implant
Currently I am trying the Fibaro Smart Implant and am currently facing a seemingly unsolvable problem for me.
I was hoping that someone here can help me.
I want to use the Smart Implant to network my alarm system with my home control.
I will connect the two outputs with the sensor inputs of the alarm system, which also works.
I have failed with the inputs of the Smart Implant.
I have gotten to the point where I have disconnected the inputs from the outputs and set them to monostable.
I have read that I need to connect the green and yellow wire (input 1 & 3) to ground to switch like a push button.
Connected should switch
Not connected should not switch
But now I can't find any clue if this works as intended. I have gained countless new symbols in the HC3 through the Smart Implant.
/monthly_2021_11/grafik.png.c00aea07fbc24e5393d0bdb1b99321ec.png" />
I think 107 and 108 are the two inputs.
Now unfortunately I have no idea how to check if this works like this.
It would be nice if someone could help me here.
Greetings Rico
Translated with www.DeepL.com/Translator (free version)
Uncheck "show hidden". Then you see what is usable at current configuration.
"Role" field is essential to understand what current current conf is like.
Edited by homeinterface
