Boiler Control
I have been running Fibaro TVR's on all of my radiators for a few years now and My old boiler have given problems with over heating when all the TVR's close due to no heat needed.
I fitted a bypass valve that lets the hot water circulate rather than just dead head.
I am getting a new boiler immanently and the plumbers merchant doesn't understand what is happing with FIBARO TVR valves and the controller.
Can anyone tell me of  a boiler controller that will work with Fibaro and z-wave system that I can program to tern the boiler off but leave the pump running?
Do I need to fit tempters sensors to the flow and return pipes to find the differential tempter of the water?
What is the simplest way to program this?
Hi I’ve a similar problem. I have 3 water circulator after the boiler ( one for each zone) without bypass, so I need to know when all the valves in a zone are closed to stop the circulator of the zone.
I see the point exposes a switch (binary sensor) what it’s for?
Anyone got an answer to this question as I have a Biomass Boiler with a large buffer tank and 3 pumps that feed different heating zones. When the Fibaro heat controllers in a certain zone need heat I want to turn the zone pump on?
@Sky lordFound a solution:
 t
