danidani 1
I have HC3 (on 5.091 beta) one Double Switch 2 (FGS-223) connected to the physical switch and one Dimmer 2 (FGD-212) connected to the bulb.
My target is to be able to turn on/off the light with Switch or to dime the bulb by mobile app, web interface or Google Home assistant.
I have created an association (Endpoint 2 | Group 2) on the Switch to the Dimmer so I am able to turn on/off the bulb (that is physically not connected to the Switch).
My problem: If I turn on or dime the bulb via mobile app, web interface or google, the Double Switch 2 status does not change so if I want to turn off the bulb with the physical switch later on I have to click it twice (first to change status of Double Switch 2 to on and second to turn it off).
How the associations and parametres should be setup to solve this?
