Wrong settings from Template on HVAC Spirit z-wave plus
For setting an external temparatur i must set Parameter 8 with value 128
The Template will set it on 1280 , this is a wrong value and the system will set 0
Please fix this one.
I think that this is related to the parameter design, there is a divider (1/10) implemented for values 0-50 (0; 5*C) and 206-255 (-5;-0.1*C)  for this offset to makes those values "human readable".
It won't be easy to change but in next version (5.092 beta) issue with setting parameters manually with disabled template will be fixed.
So, after installing 5.092 Beta which will be released soon you will be able to disable template and set this value manually.
Then, just put there value 128 and it will work.
