@m.roszakSir, hi
why you developers broke exists behavior and replace nil to null function in json.decode ?
1 hour ago, 10der said:
@m.roszakSir, hi
You mean null -> nil ?
is it a QA or a Scene - they have different json decoders...
In QA's null is replaced with json.util.null (which is a function)
    Jan
    again. Just found what response from my meteostation in raw json for some fields is null
    after decoding this json this fields was transformed to null (func) instead of nil as I expect
    more than previous version build and as far as I remember in HC2 - also was nil here
    PS: QA
    To let the decoder set the values to nil, use (they disappear from the table)
    only works with the QA decoder
    This is the json encode/decoder used in QAs
