Dimmer - Off-On scene
msialk
I have two sources of light in my bathroom. One is connected to Double Switch (light1), second to Dimmer (light2). I would like to achieve the following behaviour: IF (light1 is ON or light2 is ON) AND wall switch with Dimmer is clicked THEN both light are set OFF.
I have the following code:
However there is a problem when only light1 is ON and light2 is OFF. Then, after clicking light2 switch it firstly turns the light2 ON and then activate the scene and turns both lights OFF.
Is there any possibility to avoid turning light2 ON? In desired scenario in such situation only light1 should go OFF and light2 is already OFF so nothing should happened.
There is nothing you can do. The dimmer designed to switch the ight ON and then to send the report of the status and scene ID.
As I understand from your code, you want to turn OFF the light1 and dimmer light even when the command (of the dimmer) is actually to turn ON the dimmer, is it right?
It might be a way to "cheat" the dimmer. Since when you turn the dimmer on, it sets the last value, so please try as follow (hopefully value 1 of the dimmer is low enough and not seen)
