convert number to time
i have a number 18.9413 and need to convert it to a time string the result i should get is 18:56:29
how can i do that please?
20 answers to this question
It is not epoch, what is the logic behind your number?
Maybe not that most efficient
    amazing @jgab as always so spot on and thank you for your help.
    it is working sun times, in particular trying to get the time when the sun is 8 degrees below the horizan
    Ah, Decimal time
    Decimal time is the representation of the time of day using units which are
     related. This term is often used specifically to refer to the time system used in
     for a few years beginning in 1792 during the
    , which divided the day into 10 decimal hours, each decimal hour into 100 decimal minutes and each decimal minute into 100 decimal seconds (100000 decimal seconds per day), as opposed to the more familiar
    , which divides the day into 24
    , each hour into 60
     and each minute into 60
     (86400
     seconds per day)…
    @Jay Ess,
    are you willing to post your complete calculation sunrise and sunset? Looks interesting to use.
    Thanks in advance,
    //Sjakie
    @Sjakie at the moment it is not working properly, have managed to set it up using sample code based on a particluar time and zone but when i try to run it on current dates and time and different time zone it bring back results which dont make sense.
    once i have managed to get it working i will be happy to post it.
    I do have a sunset/sunrise calculator but it is out by between 1 and 3 minutes depedning on the time of the year, hence why i am trying to fine tune it.
    At this moment I use to minimize the deviation a correction by month followed by % clouds.
    This is close to wath I want but % clouds has sometimes a big deviation.
    What I have works more convenient as an outside PIR.
    //Sjakie
    Just checking, did you looked at this quickapp?
    @SmartHomeEddythank you for that link, will have a look at it.
    had to take down my code as posted by error.
    would you know how to get a specific time for a sun a position from that code please?
    Edited by Jay Ess
    think i am almost there, i need to take the result of this time, ie. 18:56:29 and then round it up or down to the nearest minute depeding on what i am working out, what is the most effecient way to do that please?
    Edited by Jay Ess
    function decTime2StringMinutes(a)
      return string.format("%02d:%02d",math.floor(a),math.floor(0.5+math.fmod(a,1)*60))
    @jgabthank you and use math.ceil for rounding up correct?
    so i now have a funtion to get the time, but at the moment the angle value is just a single number as in 0.83333, i want to run this function with a table of numbers, as take your function
    for a i want to pass it a table of numbers.
    function QuickApp:GetTimes()
        local sunPosition = {
            ["SunSet"] = 1,
            ["blueHourDuskEnd"] = 2
        local sortedKeys =
            getSortedKeysByValue(
            sunPosition,
            function(a,b)
                return a < b
        --local sunTimes = nil
        for _,key in ipairs(sortedKeys) do
            print(key)
    but this does not work if i call it as GetTimes()
    I have managed to build a table and iterate through it but the code seems clunky, how can i tidy this up please?
            ["SunSet"] = -0.8333,
            ["blueHourDuskEnd"] = -8
        function pairsByKeys (t, f)
          local a = {}
          for n in pairs(t) do table.insert(a, n) end
          table.sort(a, f)
          local i = 0      -- iterator variable
          local iter = function ()   -- iterator function
            i = i + 1
            if a[i] == nil then return nil
            else return a[i], t[a[i]]
          return iter
        for name , angle in pairsByKeys(sunPosition)do
            R = angle
            print(hms(T))
    If you want to print out a key/value table in some specific order I recommend you to move the key/value to an array and sort the array on the keys.
    The create an iterator like in your case is massive overkill and not more efficient.
    @jgab that is amazing thank you, if i want to have three "fields" per row of data, need to change a calculation based on what angle i need, how would i do that?
    this is what my end table should be like
            {name = "sunset",angle = -0.8333, time = "A"}
            {name = "shabbosout",angle = -8, time = "A"}
    thank you for all your help, i am one LOL step away from a working qa, i am stuck on round a decimal number as in 16.989568650404 when i do the following calculation
    i = 16.989568650404
    string.format("%02d:%02d",math.floor(i),math.ceil(math.fmod(i,1)*60))
    the retrun is 16.60 which is correct but is not a time, so i need to round it but am unsure how to do that. if someone could be so kind and show me how to accomplish that please?
    many thanks for all your contributions it really helps.
    Didn’t this work?
