Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
1. Improvements for Energy Panel
2. Block Scenes releated to Energy Panel
3. Bug fixes and improvements for Elero and Nice devices
What's new:
Access
Possibility of setting another PIN to be used for integrations in user's alarm settings.
Dashboard
Distinction of actions sent on click and hold & release of open/close buttons.
New icon of unavailable device.
Devices
Disabled logging energy consumption for hidden root endpoints of the device.
Separated configuration of saving energy to database from using data in energy panel.
New com.fibaro.multiPositionSwitch device type support.
Support for MCO MH3901-Z version 2.1.
Support for Heiman Gas Sensor (HS1CG) version 1.1 & 1.2.
Elero*
Possibility to skip waiting for limit switch report when setting the favourite position.
Possibility to retry configuration of favourite position after passing the desired level.
Possibility of re-editing the device configuration during the adding wizard.
Forced polling of added device after finishing its configuration.
Forced polling of the device after setting favourite position.
Synchronous pairing of Elero devices in Nice/Elero settings.
Displaying manufacturer, model, and version in device settings.
Silent move feature when used in scenes for Elero RolMotion device.
Energy
History tab in Panel Settings allowing to remove energy data.
Possibility of adding additional costs in Expenses tab of Panel Settings.
Redesigned interface of setting the installation cost in Panel Settings.
Overall costs added in Expenses tab are considered when calculating returns.
Graphical representation of configured rates in Tariff tab of Panel Settings.
Marking the same time ranges when comparing two periods in Savings tab.
Improvements for displaying charts in Savings tab.
Nice*
User-friendly names and tooltips for Nice device adding mode configuration dialog.
Displaying manufacturer and model in device settings.
Notifications
Notifications set in device settings may be sent only to specified users.
Other
Ability to call device actions, scenes and emit custom events via GET method of HTTP API.
Quick Apps
Expanded list of available binary sensors.
Added os.clock library.
Scenes
New category of block scenes - Energy.
Creating scenes based on summary consumption/production/balance of energy.
Creating scenes based on energy consumed by given device/room/category.
Creating scenes based on active rate of tariff.
Update
Expanded view of available device firmware update.**
Displaying detailed device update process status.**
Bug fixes:
Devices
Device polling time interval displays incorrectly.
Main energy meter energy consumption is not displayed in device advanced tab.
FIBARO Smart Implant central scene support does not work correctly.
Removed the polling interface where not applicable.
Possibility to run multiple times an active device update process.**
Cannot save value of parameter added manually.**
Device icons do not update properly when switching tabs.
Icon of gate with positioning is not set automatically.
Cannot download device template.
Elero*
In some cases, one device is not paired when pairing multiple devices.
Cannot stop pairing process after occurrence of timeout.
Redundant stop button for rotating slats.
Energy
No possibility to change filter after filtering room or category with no data.
Invisible labels in Ecology tab when using dark theme.
Incorrect plant equivalent chart value.
Gateway Connection
Icon changed for device added to slave gateway is not saved.
Updating device added to slave is terminated by updating device added to master.
Resetting the Z-Wave network is applied only to master gateway.
Favourite position of device added to slave gateway is not saved.
Incorrect update status of slave gateways.
History
Events are displayed even though saving events to history was disabled.
Network
In some cases, Wi-Fi network disconnects and does not reconnect automatically.
Nice*
Some Nice Mono devices have incorrect device type after performing update.
No possibility to close the adding dialog while binding new device.
Scene triggered by Mono remote does not control Mono shutter.
Notifications
Fixed titles of notification templates about opening/closing.
Other
Possibility of entering into inoperable recovery mode via remote access.
In some cases recovery mode is not fully loaded.
Plugins
Fixes for Philips Hue plugin related to speed of adjusting brightness.
Fixes for Tedee plugin related to unexpected disconnection.
Fixes for Fibaro Heat Activator plugin.
Profiles
In some cases, switching the profile results in an error.
Quick Apps
Connection does not close when using http client.
Scenes
Removing device used in the middle of the scene results that scene does not fully run.
Known issues:
Sceny
The energy block scenes feature is a first version which may contain some issues.
Z-Wave Engine 3.0
Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
Gateway connection is not available in the new Z-Wave engine version.
* - does not apply to HC3L (Home Center 3 Lite)
** - applies only to Z-Wave Engine 3.0
