Constant reboot. BUI = Error 503 - Server unavailable
I updated to last beta and my HC constantly rebooting with various delays - can work 1 hour and go to reboot, or can work just 5-7 minutes and go to reboot.
@m.roszak, maybe you know - can I fix it on my side? before this beta my HC3 work stable several weeks.
If needed - I can give remote support access today.
Thank you in advance.
PM send :)
It's not a bug, it's a feature
I have The same error but one once or twice per week
similar problem in my HC3
I think the frequency of this error depends on number of changes (i.e. changes of variables, editing of QA etc.) in HC3 that you do ...
This particular issue on @afendikov is diagnosed and will be fixed in next version.
It can be also fixed with remote access if someone experiencing similar issue (system does not boot up correctly most of the times and restarts).
If someone experience this and want to stay on this version please PM me.
Michał
  • 3 weeks later...
Hi, my HC3 restarted after update every 30sec, it was enough time to start downgrade procedure and I'm now on 5.091.
On HC3L it seems it was stable, but yesterday was it same, periodically restart
It seems with more devices shorter time for restart.
New version is panned for this week (start of the next in worst case).
  • Like 5
I have been having this since the launch of this Beta, I have reinstalled twice having restored back to the previous with no issues.
I have as Fibaro advises cleared Browser Cache and  used MS Edge, Chrome and Firefox with the same issue.
Ping is a constant 3-5ms so not the network stack, most likely the WebServer
@Fibaro help please
@Fabaro,
Also I note my HC3 after the upgrade does not show up on the Fibaro Remote Access  - Home Centre List is is Red : not available.
Brent
21 hours ago, BusterB1959 said:
@Fabaro,
Brent
I have had to revert back as within 1-2 minutes of authenticating logon to the console I was being thrown out and having to log back in. I see there is a Fix which is good. see above by Michał
Edited by BusterB1959
