I have an LED lamp that work on a transformer and connected to Double Switch 2 module . Everything works normally, but sometimes when I turn it off, the light does not go out and you have to knock on the module to turn off. As the electronics engineers told me, when turned on, the transformer from the lamp gives a pulse of a large current and the contacts from the relay stick to each other. How can I avoid this problem?
Merry Christmas! There are a lot of similar reports on here, and you've correctly diagnosed what is going on. Two options: find a different transformer that has a lower in rush current, or add a larger relay between the fibaro relay and the load, that can handle the current. This relay is known as a slave relay.
