OLEH 0
I have thermostats (MH7H-WH). after connecting, everything worked fine, but after adding the thermostat to the z wave network (fibaro hc 2 controller), it resets the set temperature (either by 18 degrees, or 19, or 21 degrees) and then keeps this temperature. I ask for help. Thank you.
